I have a lift handle in my garage with no bolt in it, you can have if you need one with no bolt in it. ;-)
Reactions: ProfSnape
Thanks CharlieVT for the link. I will try a few other ways to remove it and make sure the bolt gets back in :wink:, johnbaker15.
Piece o cake. You just need to have patience. Lift your seat. I break the starter force with a Γ type allen wrench. Then use a screwdriver allen the same size (I believe it's 5mm if my memory isn't tricky to me) with a balled head. It came out in three minutes. You bolt it on the reverse way. You just need a pair of tweezers or bended long nose pliers to hold it and drive in place.
With an extension under the frame tubing and patience
