1 - 20 of 23 Posts
On my K1200LT - To reverse,
Engage neutral, Twist knob, Press starter.
The engine revs and the bike rolls back about 18 inches then the reverse disengages.
Hold down starter button and repeat for another 18 inches or so back.
Is it cutting out early ? Should the bike roll back until the button is released ?
Something is not working right.. I put mine in reverse and as long as i hold the starter button down, it continues to reverse.
Mine stays engaged as long as I'm hitting the button.
I believe this is caused by a faulty or miss-adjusted speed sensor. Let me check on that and find a thread.
EDIT: Yes, the threads I find indicate the speed sensor on the transmission or possibly a bad reverse controller.
You can try and clean the speed sensor or replace it if that doesn't help and after that, I would look at a reverse conteroler from flebay
Are you on a flat surface they dont like ramps ect
Mine has always worked as you described, just a bit longer. Engages for about 1-1.5 meters the cuts off. Possibly to avoid overheating the starter motor. Not 18" though.
It should run until you release the button. If it doesn't, there is a problem.
Oh!
Mine goes into reverse, light comes on but it does not move when I push the starter button. Is this the reverse motor that is bad or could it be gunked up?
Ramps (within reason) shouldn't be an issue. A flat surface almost defeats the purpose of having reverse. I use mine to back into my garage and my driveway has a decent downslope and never had a problem. I could see a great enough slope being more than the starter torque can overcome but that's about it.
The reverse motor is actually the starter motor so you have a different issue as long as the bike starts normally.
I don't mean to be argumentative, but having read up on the reverse system, it has nothing to do with the starter. There is actually a revers gear in the transmission, therefore ramps should not have anything to do with it. As an experiment and if your balance is good, try and give it a little gas and you'll see that it actually speeds up.
HMMMM. I may have to "reverse" myself.. I'm reading conflicting discussions on the K1200lt reverse system. Some say it's an actual function of the transmission, and others say it's the Starter. Now i'm really confused, as My Dealer in Jacksonville specifically told me the reverse had nothing to do with the Starter. I look at transmissions for sale in various outlets, and they all say K1200lt transmission with reverse.. If anyone has a definitive guide to this, i'd sure like to read it. As a side note, i've had absolutely no issues reversing even with a steep incline.
Discussion Starter #14
Thanks for the comments.
Obviously there is a problem with a faulty part somewhere.
However I still have reverse - I just have to do it in a series of inelegant steps while others glide serenely backwards.
This is near as I can get with an explanation.
when you shift into rev there is a dog gear in the top of the g/box that that slides across connecting the starter drive with the gear, the reverse controller limits the rpm so that the bike doesn't go flat out backwards and yes it is driven by the starter motor. As said if you hold the button down it should keep going until you release.
Mine did this after a bmw service many years ago they left a wire unplugged to the rev controller
When I push the starter button for reverse mode the RPM steps up a bit. I always assumed it was because of the significant amount of reduction gear from the starter to the gearbox, and to keep the battery happy. I have never tested it, but it feels like is has plenty of torque to make it up a ramp. this is making me want to try something crazy with it (here hold my beer and watch this).
My 2007 K1200LT did that under warranty...the reverse controller was replaced, which fixed the problem.
Most likely cause is a bad speed sensor. It tells the reverser controller how fast you are moving and if it gets no signal it stops until you press the starter button again. I would change it $ first before I went after the $$$ controller.
I found this on a copy of the owners manual:
"Do not operate the reverser for more than 1 minute – bear the state of battery charge in mind. The reverser switches off if it is overloaded."
I also believe I read somewhere that reverse is limited to 1mph, if it exceeds that I believe it will switch off as well. That would lead me to believe the speed sensor is at fault. It is possible the cables to the starter/battery could have a bad contact or something is overloading it but my money is on the sensor.
As many have already stated. This is a "classic" fault. It is fault in speed sensor on top/side of gearbox or the connector to it (like I had).
1 - 20 of 23 Posts
