Most of the tank bags I've been looking at use a 3 point hook up. The front two loop around the handle bar column and the rear attaches under the seat. I've figured out the seat attachment. But because the EWS switch rotates around the column, there is not room for a strap to go around and under the steering column. So, how does one attach it? There are two small connecting rods on either side of the column but that would require two separate and independent straps up front. Since my GPS and XM antenna are sitting between the bars, I can't use a flip up bank like the Big Mak. I've talked to Linda T.(Custom TankBags) a couple of times but her bags use the front loop system, she is supposed to go look at a GT and see what she can do (like make a custom bra). Any suggestions?
