Kinda depends on where you want the lights, exactly. The electrical part is easy - just use the feed to the parking bulb in the headlight.
LEDs or 'neon' kits under cowel for 'effects' light.
Clear lens covers on turn signals - colored LEDs inside turn signal units.
Guess it depends on how 'visible' you want these to be - same or similar to running lights or just an effects deal. May require adding a 2nd 1156 socket to your turn signal housings - involve a bit of work. Then use theatrical bulb dye or gels to color...
Me? I'd go the LED route - use as many as needed for effect.
Crap, now there's an idea - acrylic rod 'light pipe' from an internal bank of 'super brights'. Much easier to do than a 2nd socket or discrete LEDs in the housings. Man, wish I'da thought of that a few months back before I poked all these hols in the signal housings for discrete LEDs. May be time to 'pach' those holes and try a plan 'b'.
