Maybe we can talk Mike Haughty into bringing the spring changing jig he made up.PoppaT said:I vote for 26th. Tire pressure monitor & hyperpro springs, if possible (I bet the springs will be my winter project).
Thanks Karl.ksbaltz said:I'll call Haughty and see about the compressor.
Hi Kris. I do have an extra set of stock shocks with Hyperpro springs installed. If we don't get thePoppaT said:I vote for 26th. Tire pressure monitor & hyperpro springs, if possible (I bet the springs will be my winter project).
Fred, I have 2 spare motors for the centerstand. Let's try that out before you buyfwkraft said:Dan,
Hope all is well. The 12th (Mothers Day weekend}, 19th anniversary - so 5/26 would get my vote. Need front/rear tires and centerstand (still trying to buy one).
Welcome back Mike.haughty said:Immmm backkkk!
Jeez louize a two week training turned into a 7 month training/ production run!
Was in the garage last weekend and noticed the fixture by my workbench, and yesterday Karl called..
We can do!
The big girl wasnt ridden much last year seeing how brazil, Tulsa and Washington DC was good for about 9 months out of my year!
Since im taking Friday off, its time to change those fluids i was meaning to do last tech session.
My needs for tech session, is change the front tire... You guys saved my bacon last year when yall found he GT rated tire on the rear.
My tire might have only a 1k on her since the session...
if i can ask, is check valves unless Karl does his and maybe i can mimic at his house to see what my numbers are..might not need anything ( crossing fingers)
Would be good to see yall again!
Mikey
Hey Kris,PoppaT said:I vote for 26th. Tire pressure monitor & hyperpro springs, if possible (I bet the springs will be my winter project).
"New place"? that's news I missed.DanMartin said:Welcome back Mike.
We can do the tire and valves. New place has more room too I hope.
I am taking off Friday too in hopes of epoxying the garage floor.
Yes, we are downsizing. Moving out to Fulshear. Closing today. Moving Sat. and the next Sat.dukey33 said:"New place"? that's news I missed.
The only work I might want to try is if a spring compressor is available and if it works on an Ohlins, I would like to crank up the static preload a bit.
Also depends on which day this ends up. Wifey is wanting to take a weekend in May to somewhere. We both need a break.
