I am working on a friend's 2002 K1200LT that would not start. I discovered that the alarm system went bad and it shorted some of the wiring in the relay box under the tank and kept blowing the fuse associated with the horn. I removed the alarm module and made the jumpers based upon what I found on the forum on the 12 pin connector under the trunk hatch box and she finally runs. Now I am having trouble with the horn. I am not sure if the horn problem existed prior to the no start. Initially if I press the horn button, it blows just fine. If I press it 3 or 4 more times, it will not blow. I disassembled the horn switch and tried shorting the two wires to see if the horn will just blow and blow. Unfortunately nothing happens. I attached a multi-meter on across the two wires and I didn't get any ohm reading when i press the horn switch with the power off. Could I have a faulty switch or is there something else that I need to look at? It looks as though the switch could be failing intermittently. Any help would be appreciated. Thanks Darryl
Discussion Starter #2
The problem is fixed. I did not seat the horn relay in the socket properly when I rewired the melted wires. Once the relay was inserted properly, the horn blows strong and loudly!!!
Very Horny indeed :eek:)
Glad you found the issue but it bothers me that there was melted wires. Usually when the alarm goes bad it just blows the fuse which is a 15 amp so the wires should have been protected. Maybe the owner tried a bigger fuse before he brought you the bike?
