Hello,
I've have som noise from the engine and I want to chek that the chain timing is adjust right and that the tensioner work fine. Is it a way to have a sevice on the tensioner?
Tor :)
no there isn't, it is not adjustable. but if the guides are worn or oil pressure is low may be the cause of you noise , what does it sound like? when does it happen? you will need to provide a lot more details,
There have been a few cases where the oil pressure piston was stuck and not applying enough force on the chain tensioner. Only way to check is to remove the timing cover.
Hello,
Tor :)
Could it possibly be alternator rattle at idle speeds?
Robert
