1 - 20 of 28 Posts
I've scanned the archives for information on installing a H3 HID bulb, but haven't found the answer to my dilemma. I'm using the DDM Tuning HID kit. I have filed the black plastic collar (picture #1 ) where it I can pass the bulb through it. However, if I install the bulb in this configuration, it is loose and the copper retainer does not secure the black bulb housing.
Looking at the stock bulb configuration, the bulb is secured between the black bulb housing and metal retainer. The bulb sits on top of the black bulb housing and the metal retainer secures the bulb in place. If I attempt this path, the ballast connectors and rubber grommet are too large to pass through the black bulb housing. I don't have much plastic remaining to file.
Anyone have experience installing the DDM Tuning H3 bulb?
Rob, 2000LT
Navarre, FL
Are you sure you have the right kit? The main beam on my 2002LT is an H7 as I recall, not an H3. I haven't yet done the HID conversion, but I'm thinking an H7 HID conversion might be more appropriate.
I'm installing the high beam (H3) HID kit. I installed the low beam (H7) bulb last Fall.
Rob, 2000LT
Navarre, FL
Rob, 2000LT
Navarre, FL
I thought it was not advised to put an HID in the high beam because of the warm up time needed for the high beam and the possible wear and tear on the ballast.
Hey Rob not sure of what you are up to but the bulb should go straight in, they are correct fitment check the base of the old globe against the new hid, make sure you keep your fingers off the bulb.
Nick you are back to front the H7 is low beam.
Rdpas there is no "wear and tear" on the ballast other than normal usage but you are sort of right, there is a delay switching on, but our low beams are on all the time so you would hardly notice, the problem comes when you dip from high to low using hid if your low beam goes out when switching to high beam, you will have a small period of time with very low lighting until the low beam warms up.
Rob, 2000LT
Navarre, FL
Rob,
The implementation of High beam bulb holder was not designed for an HID, but with some patience, a few bad words, you will get there ;-)
Fortunately for you, the K1200RS has the same H3 bulb holder and we have a few members on the K1200RS forum who did the same job.
See this PDF file attachment:
I-BMW.com
The PDF file came from this thread where you will find more ideas and pictures:
HID light installation, '02 K1200RS - I-BMW.com
Rob, 2000LT
Navarre, FL
Rob here is what I did 10 years ago. Yes the bulb is loose in the black capsule retainer. I secured my HID bulb to the capsule with lineman's tape found at Home Depot. Just stretch and wrap the tape around the rubber of the bulb. Be sure to align the HID bulb in the capsule just like the stock bulb.
I carefully removed the grommet from the wires, cutting with a razor blade. I then filed a opening on the left side of the headlight plastic cover for the wires to fit into the headlight housing. Connect wires then Seal with RTV. HTH
Sailor, thanks for attachment and advice about being patient. After careful filing of the H3 bulb bracket, I was able to insert the H3 HID bulb into the holder.
Now my next questions, there is a black and red wire for the HID bulb (pic A) while the stock H3 bulb only had a single white wire (pic B). Am I correct to assume the HID red wire should be connected to the stock white wire location? If my assumption is correct, then what is the HID black wire for and where would it be connected?
Thanks for the assistance,
Rob, 2000LT
Navarre, FL
Yes the white wire is positive connects to the red on the HID. The black wire then is the negative on the HID and the brown wires on your bike are negative. I have HID in both, but I cannot remember for sure how I hooked all this up.
I think I used piggyback spade connectors.
Murray,
The H3 bulb felt secure in the bulb's bracket (black capsule) when it wasn't in the headlight assemble, but I'm not so lucky. The bulb has some play in it now that it is installed. I did a search for linesman tape, but had zero hits. Is there another name for it?
Additionally, I'm still scratching my head concerning the ground. I initially thought I would use one of the ground locations (brown wires), but then I was concerned the ground location was for another sensor or junction. I ended up grounding it to the screw that secures the connector for the white hot wire. Does anyone see a problem with that ground location? I hope to put it back together in the next couple days, but this daily event called worked is getting in the way.
Rob, 2000LT
Navarre, FL
Murray,
Rob, 2000LT
Navarre, FL
I would plug the wires into the stock bulb socket. Red to White Black to Brown.
Lineman's tape can be found at Home Depot in the electrical dept. The standard black electrical tape can allow electric leakage, lineman's tape will not leak. The tape streaches and contracts on the surface applied to.
If you mean the screw in the photo, no that is not a ground. The only ground on a BMW is a brown wire. Not even the frame is a ground. The red circle shows the ground for the high beam.
Discussion Starter #13
JZeiler,
When I removed the OEM bulb, there was no ground wire associated with it. Only the white wire in the photo. I originally considered the two brown wires for the HID ground, but did not know if one of them was the grounding point for the high beam bulb or some other important piece of equipment. Do you know which brown wire is the ground for the high beam? The top brown connector or the connector below it?
Rob, 2000LT
Navarre, FL
JZeiler,
Rob, 2000LT
Navarre, FL
The high beam is grounded through the metal tab coming out of the bulb holder. If you look at John's picture you can see it. All the brown wires in the headlight fixture connect together. The easiest way to connect your HID bulb is to get a piggyback spade connector. I think I may have pictures of the way mine is done, I'm just not sure where they are stored and I don't have an account on a photo sharing service. If I can find them I could email them to you.
Discussion Starter #15
Buff8stuff,
Good info. I was unaware of a "piggyback" spade connector. That was a key piece of information I was looking for. I'll visit my local Radio Shack. Removing the OEM grounding metal tab as part of the HID bulb holder modification is the root of my confusion. Where does the HID ground connect with the metal tab from the OEM bulb holder removed? Sounds like a piggyback spade connector on either of the two grounding tabs will solve that mystery.
Thanks for help,
Rob, 2000LT
Navarre, FL
Discussion Starter #18
Buff8stuff, thanks for the offer of the piggyback spade connector. My local and independently owned Radio Shack had them in stock. I probably wasted an hour and much frustration before your suggestion.
The HID bulb is still not as secure as I would like in the bulb holder. I'm going to attempt to tighten the bulb with a rubber grommet. Hopefully I didn't file too much plastic from the holder. Fingers crossed.
Rob, 2000LT
Navarre, FL
Rob, 2000LT
Navarre, FL
Just out of curiosity, do you know how the independent dealers are doing as far as support from the corp. I think all the outlets in Salt Lake are closing, some are becoming Sprint stores.
Glad my suggestion helped. I use so many piggyback connectors I ended up buying a bag of 100.
Enjoy The Ride
I used silicone to hold my bulb in place. Somewhere on this site are pictures on how I grounded my two HID lights
1 - 20 of 28 Posts
