1 - 20 of 23 Posts
· Registered
I am going to put a radio in my bike that I got from another member and I'm going to use a hidden antenna. I plan on putting it the spot that was vacated by my cannerstectomy. I need a 12v switched power source. Can I get my power from the tail light wire and if I can what color wire would it be? If that is not a good idea where would I be able to get the switched power from?
· Registered
You may want to consider purchasing a fuse block http://www.fuzeblocks.com/ then get power from battery and a relay triggered by the small marker light in the headlight assembly. This would give you a good electrical foundation for adding even more bling AKA accessories.
· Wrencher Extraordinaire
Fairly close is the rear seat heat connector, Green/Brown wire is switched.
· Premium Member
Unfortunately, most 99s had a different wiring harness leaving out the connectors for heated seats (if it didn't come with heated seats).
It will take some time to get to, there is a connector on the right side for a 12V jack, like the one on the left side that actually has the jack installed.
I've never looked at it but there is a 12V jack on the left hand side of the trunk, behind a passengers elbow.
I imagine that one could take a multitester and find which wire in the barrell connections for the trunk connects with the plus, inner conncetion, of the 12V jack in the trunk.
Disconnect the barrell conncetor and go from one pin to the next while holding the second probe into the 12V jack.
Bob
· Premium Member
Try a TuneTrapper antenna (no affiliation).
Great performance and NO power needed.
· Registered
Munmi said:
You may want to consider purchasing a fuse block http://www.fuzeblocks.com/ --------------------------------------------.
Sadly, the developer and owner of Fuzeblocks, Curt Gran, was killed in a motorcycle accident a few weeks ago. The web site is still up, so hopefully his family will keep the operation going. It is a great, and very innovative product. It would be sad to see one of Curt's legacies fall.
· Premium Member
MartyBlok said:
Tony, where did you mount the Tune Trapper antenna on your LT?
Marty,
I have it mounted between the plastic tray and the top case; there is just enough vertical clearance for it to fit.
The antenna lead follows the same path as the factory antenna did, and simply plugs into the antenna input jack the same way the factory lead did.
Make sure you call and order the 16" version so it fits. Not on their website yet, but they are available if you call.
HTH
· Premium Member
RVB1019 said:
Stupid question- since I now stream music via my Zumo to my helmet, I never need the antenna. What would happen if I simply snip the whip?
The paint will peel off the bike.
If you are going to snip the whip, why not pull the top case and remove the mount and coil?
Only four screws to remove the top case, pull it off towards the right side about three inches (no need to remove it from the bike), unscrew the two hex socket screws that hold the antenna mount to the bike, snip the antenna lead, and refasten the top case.
I left the antenna mounting screws in their respective holes after removing the antenna. This way I know where they are in case I ever decide to use those mount points for some other project...
· Registered
· Registered
deputy5211 said:
Marty,
HTH
I got a tune trapper and it works well.
I did not want to run mine all the way to the back like deputy5211, so I just stuffed mine up under the left trim panel. I found the antenna cord end under the left trim panel and while I had the left spoiler (lower) off I just stuck it up under there.
Seems to work well, but I have not really listed to the radio that much lately.
I have gotten 500 hours of "This American Life" in MP3 format and have that playing to my SRC of the Schuberth from my iphone for the last 10K miles.
Sure makes the time go by fast.
· Premium Member
That is a creative place to put it, and leaves one less cord running fore-aft. My only concern would be heat from the engine and/or roadway. Fairly well vented area, so probably not an issue. Not sure what is inside the TT antenna, but I would hope it is not highly heat sensitive.
· Registered
Thanks Deputy, now I have one more thing to worry about..
· Premium Member
Paul,
Not to worry...there isn't anything in that antenna that would be heat sensitive. It's a called di-pole antenna and has higher gain than a whip antenna. No components other than wire. :)
· Premium Member
At you service, sir. :rolleyes:
· Registered
deputy5211 said:
Marty,
HTH
Hi deputy, u run the antenna wire all the way from the radio unit to the back of the bike? I ordered one with two foot antenna wire, wondering is it long enough?
· Registered
deputy5211 said:
Marty,
HTH
Hi deputy, u run the antenna wire all the way from the radio unit to the back of the bike? I ordered one with two foot antenna wire, wondering is it long enough? :confused: That will be quite a lot of parts to remove? This will be my first attempt to remove the bike apart...
1 - 20 of 23 Posts
