1 - 1 of 1 Posts
Here's a good source for HID headlight installation and replacement bulbs.
http://www.kbcarstuff.com/Xtreme-HID-Components-s/31.htm
Replaced both bulb and ballast with the Extreme 4300K bulb and Extreme Ballast and it works perfectly with the stock bulb wiring harness/connector inside the headlight assembly. No other wiring necessary. Eliminated two other wiring rigs installed with original HID bulb at a Curve Cowboy reunion in 2003.
Had to drill a new 1" hole in the headlight cover and all the wiring worked great.
1 - 1 of 1 Posts
