Just got the HID Conversion kit from Fashtek. Is there an install thread on this site or does someone have ideas on how and where to put the box?
Discussion Starter #2
By the way, it is only the high beam.
Thanks, but I need it for an 2006, or is it very similar
2011 R1200RT
Although that is a bit odd since the low beam is really the one needing an upgrade, I hope you got the right bulb - H9 or H11.
Huh? I'd advise against. Cannot use "flash" function, unless you have separate driving lights that come on together with the high beam circuit. HID light needs time to warm up.
Best setup is HID low beam (H7 bulb) - which stays on in high beam mode as well. Leave High beam bulb as halogen.
BTW, you will be impressed with the low-beam conversion results. Works great.
Guess I need to order the low beam also. Thanks.
2011 R1200RT
Probably a good idea, however the installation get a little more complicated since you need to find room for 2 ballasts and igniters. No big deal if you are comfortable removiong the nose cone.
IBR# 366
Who uses the flash function while riding? I just don't ever think about it.
2011 R1200RT
I do when I lane split, in addition to my DD and PIAAs, and Stebel horn... What can I say? I guess I like light and sound shows!!!:D
