1 - 3 of 3 Posts
Hi all
this may seem really dumb, but I sold the 6-disc changer from my bike and I can't get the smaller of the 2 electrical plugs to let go. I don't want to damage anything, is anyone out there with a sugestion??
Discussion Starter #2
Update
After about 30 minutes I finally got the thing un-plugged !! I don't know why it was so tight. Anyway thanks for the help I'm sure was on the way. :) :bmw:
Gently rock the connector back and forth, up and down. Do not pull by the wires. Try using your fingers only. Look for a locking tab. Most can be released with a very small screwdriver. Use small needle nose plyiers if fingers won't work. I've had mine out several times, easier 2nd time. I did short it out once, blowing a fuse under rear seat.
1 - 3 of 3 Posts
