1 - 20 of 28 Posts
Hi guys,
This is for a 1999 K1200LT.
So the rear Metz 880 needs replacement after one year. the tread is almost flat and I got a puncture the other day.
I am debating if I should repair the puncture myself to get few more miles out of it or replace the tire.
The question again if I should stay with the Metz or go back to the Bridgestone 02 ??
And since these tires are expensive, does anyone have a used tire they want to sell ?
I am in San Jose, CA.
Might as well ask this too: Anyone nearby has a mounting and balancing gig for the tire?
Thank you,
AJ
Bite the bullet and get a new 880. Call around and see if you can find a shop to change it if you bring in the tire. Some will. Even better if you take off the wheel and just take that in. Maintenance and consumables cost money, bikes are not cheaper than cars.
Tires on the web are 1/2 to 2/3rds cost at the dealer.
You are not going to find an ME880. If you do the date code is going to be old.
As for used tires... You only have two wheels under you. Buy new! It is cheaper than skin grafts.
160/70B-17 (79V) Metzeler ME888 Marathon Ultra Rear Motorcycle Tire Black Wall
Part# 1487820011
Our price: $176.88
https://www.jakewilson.com/p/1184/46628/Metzeler-ME888-Marathon-Ultra-Rear-Motorcycle-Tire
Yeah except that the 888 rubs on the right side and would need a spacer...already tried that. Some say the spacer chages the geomtry of the bike and thus should be avoided.
Is there a Huge difference between the Metz (79V) and the Metz (73V) as far as this bike (KLT 1200) is concerned ?
I mean, in practical terms taking the bike weight into account, is the 73 V tire fine/safe to use with this bike ?
Thank you so much.
I am always concerned when someone tries to save a dollar on a safety item that could hurt or kill you and possibly someone else if it failed. I appreciate saving money just like the next person being retired and on a fixed income but tires ,brakes, lighting, etc, help keep you safe and alive so please go for the new not used. If you do find a used tire, "ebay for instance" make sure the date code is not more than 6 years old, good luck.
Part# 1487820011
Our price: $176.88
So are you saying the Metz rear is better choice than the Bridgestone tire for this bike??
I mean Better as far as the longivity and handling.
Thank you.
I'd go with the Bridgestones. The rear 160/70/17 79v rated.To me they have better all around traction.Never was a big fan of Metz. Just make sure you keep the pressures at 42 front, 48 rear all the time. I get 7 to 12 K out of a set. Depending how many twisty roads i ride. A combo some on this forum run is a Metzeler front, and a Bridgestone rear. They seem to get good mileage out of both.
Reactions: beech
I use and like the metz 888. No problems except for you might have to add a 2nd wheel spacer, as the 888 is about 1/4" wider and some folk have rubbing issues on the swing arm. Mine was too close for comfort so I added a spacer. The spacer is 2mm thick and with the diagonal angle of the swing arm, each 2mm spacer only buys you about 1mm extra space.
But I like the tire. And like having a wider tire under this large bike.
I'll know by the end of summer about mileage, as I have an extremely long ride coming and already have several thousand miles on the tires (both metz).
Bob
Here is that Bridgestone, $145. If you order the matching front shipping is free:
BRIDGESTONE BT020-M 160/70B-17 M/C 79V, REAR
Now you need to call around and find someone to install them. Takes an hour to 1.5 hours to do the job so there is some money too. If you can take the wheels off yourself you will save quite a bit.
Thank you so much.
Due to the weight if the LT, it requires a 79V rating and should have REINF on the sidewalls. Not worth a blow out.
The first Metzler rear tire I had installed by a local motorcycle tire specialist (that rides an RT) was the non-reinforced version and he reassured me that it was good for the LT. After reading all the literature on LT's needing reinforced tires, I came to the conclusion that my specialist was more interested in selling one of his "in stock" tires, than actually satisfying manufacturers recommendations. I was happy to finally replace the non-reinforced version with the 79V reinforced and have not gone back to that guy. One other issue to consider is the possible effect on insurance payouts should you ever have an accident due to tire failure from using an under-rated tire.... My '07 has had Bridgestones front and rear, and I plan on replacing the front with a Metzler next change, but staying with the 'Stone on the rear. >:)
Thank you so much.
You really think that moving the rear tire 2mm to the left is going to be noticable? Ridden mine on 2 long trips and several 2 or 3 hundred mile trips. Been riding since 1968 and I cannot tell the difference. The bike handles great, inline with my abilities and spidey sense.
.02
I installed the Avon on rear of my '99. It seems to stick the corners better for me; with Bridgestone on the front. And yes, the Avon is 79V REINF rated for this flying brick.
Just remember one important thing! A proper new tire is a lot cheaper than having to pay the funeral home or a serious hospital bill. Ride safe.
Leon
Discussion Starter #18
Then he should buy the cheapest tire that fits that includes a 79V rating.
You both are wrong, I am worried about safety. I am simply asking what will work/safe on this bike without spending a fortune. Of course you can read it anyway you want to read it.
Discussion Starter #19
.02
I really don't know since I have not yet tried it (installing spacers with the 888). The dealer tells me few MM will change the bike geomtry and steering, others tell me something else.
It is difficult to know who knows what they are talking about anymore.
Dealer is very wrong. I have set up rear wheels 1/4" off center. I will say that that was for a sidecar. I did and have put many miles as a two wheeler with that wheel. If you think about it the rear will follow the front. It is a self correcting.
Robert
1 - 20 of 28 Posts
