ebear695 said:
Tony I'm trying to find instructions and maybe pictures for removing the dash cover to access the area above the instruments and below the windshield, the area of the map light to install the old style Nav mount.
Eddee,
Go to the files ( link at top of screen) area look for the file "BMW Navigator GPS install instructions " that will tell you how to install that mount. It is a PDF file so you can save it to your computer and open it there. BTW you will not need to take the left side tupperware off for just a mount install, only need to do that if you are looking to install the entire kit.
For the windshield removal, type just that in the search area (windshield removal) go to the ones that have both windshield and removal in the title.
One thing that I did early on to this forum is read almost everything in the "Hall of Wisdom" (AKA HOW), go to the Technical drop down at the top select Hall of Wisdom. I have to go back every now and then to remember stuff.
Here a couple ways to search;
Basic Search Syntax
•Search multiple words use Boolean operators such as:
- AND (ex. ajax AND instant)
- OR (ex. ajax OR instant)
- NOT (ex. ajax NOT instant) or use the minus sign (-) (ex. ajax -instant)
•Search for an exact phrase using quotes:
- (ex. "instant email")
•Search for wild cards using asterisks (*)
- (ex. *mail)
HTH :wave
