2005 LT with 17,000 miles.
Driving on Saturday night I got the ! symbol in the triangle, usually a brake lamp out.
10 minutes later, after stepping on my rear brake, I get the BRAKE FAILURE flashing, I think once per second. My brakes took at least twice as long to stop.
I was a mile from my girlfriends, so I limped over there. At three stop signs, I turned it off and started it up again. All systems go - for the moment. The problem started up again when I used the back brake, not the front.
As I got closer, I noticed the bike was driving like it had one brake applied all the time - a dragging sensation. After a stop, it was tough to get it rolling, but now I was two blocks away, so I carefully drove into her garage.
When I stopped the bike, I couldn't get it to roll. I went upstairs to get her and see if both of us could push it. By the time she came down (5 minutes), it was rolling a bit freer, but still dragging. We pushed it into a parking space.
I touched the rear rotor. It melted my flesh immediately. It took over an hour to cool.
Last night I popped out the rear pads to see if maybe I was on the backing plates as I didn't check them when I bought the bike. Still, there was over half the pad left. I put everything back together.
This morning, I started it up and rode it around the parking lot at about 15mph and made 4-5 stops. NO PROBLEMS! However, this started as I was exiting the freeway, I was slowing from about 45 mph the first time it happened so a slow speed test might not tell me anything.
LASTLY: I had just finished washing the bike with a high pressure washer. I hit it from every angle to get off the dirt from the last 3 months. I used a blow dryer for 1/2 an hour, toweled the rest of the water spots off, got on my gear and drove away. Is there any reason to suspect water somewhere it shouldn't be?
I called BMW of Hollywood and they won't be able to get it for a couple of days. He said this all sounded very weird - haven't heard anything like this that he could recall. Didn't think water should cause a problem.
What do you all think?
TIA
TIA
