OK this is dumb how do you get the cover of the back of the lowbeam headlight ? I see the wire and I have pulled it down but the cover still dose not come off !
First, check the fuse.
I think there are several threads about getting to the back of the headlight on the forum.
If you are speaking about the spring wire clip that holds the back of the bulb base, then just that part comes out, thus exposing the bulb for re-placement. DON'T touch the new bulb with your fingers as it will drastically shorten the life of the new bulb. Stick the base and bulb back in and flip the spring clip back in place.
Hope that helps a bit!
Vern :bmw:
After the hold down wire is removed the seal of the cover has probably stuck the cover on the housing. If you can't pull it off with a lot of effort, try to pry it off with a common screwdriver at the seam. It will pop off eventually.
once the wire clip is off the plastic cover just pops off, give it a rap with a small hammer or use a pry.
R
