1 - 13 of 13 Posts
I'm going to install a DDM HID H7 low beam in my 2000 K1200LT any step by step or tips on doing it?
Jim
Jim, I'm not sure exactly what you are looking for in the way of help. A search will bring up lots of hints, step by step instructions and pictures of several installations. Is a DDM a special HID?
I installed a HID on my 2002 when it was new and found that removing the nose cone made the job a little easier. Some have done the job without removing it. The entire project took less than 3 hours.
+1 on removing the nose cone. I have installed HID twice. The first time without removing the nose cone. The second time (to install the high beam), I removed the cone and found that getting my giant ham-fists in there was a lot easier. Also, a lot easier to conveniently anchor the ballasts, IMO.
2011 R1200RT
Without removing the nosecone, took about 45 minutes on a pre-05 to install the low beam only.
It is nice to have a lift, but if you don't and if you own a very large dog you can "borrow" the 50lbs bag of dog food to rest on while connecting everything.
Jim,
I just installed the same item from DDM last weekend, I took the nose cowling off and removed the headlamp assembly. Its so much easier to work on at workbench height. I used heavy duty self adhering velcro to stick the ballast on the ledge over the headlight.
easy job, just takes a bit of time.
Ron
Hi Jim,
I just finished my HID install today, and it took me about an hour :D . I did the install without removing any tupperware at all :dance: . I was able to access everything from under the front of the fairing and it was almost as easy as just replacing the bulb.
I purchased my kit on eBay from Xenon Warehouse for $35 with free shipping. It's a Ultra Slim Digital Ballast HID Conversion Kit for the H-7 (Low Beam), 35 watt, 5000K Bulb. The Ballast is thinner than a AA Battery and smaller than a credit card, (3"x 2.5" x 0.5").
I got the kit for a car as it comes with two of everything so now I have a complete back up in the saddlebag. The kit is "plug and play", 100% vibration and waterproof with a one year warranty.
It works great and the light is "Awesome". I was convinced by all the others on this site that did their conversions and I can see why they did. It was easy and the results are unbelievable.
Have fun doing it,
Mike :D
Hi Mike,
Your post regarding your HID install encourages me to jump in and do it for my 2000 K1200ltc. The stock lighting is really pathetic.
I wasn't able to locate Xenon Warehouse in eBay; I did find hid_xenonwarehouse1818. Is that the correct store?
Thanks for a reply.
Michael
Micheal - I couldn't find the Xenon on ebay either so I went with the DDM tuning kit. The website says they're based in San Diego, but the kit came from China. I wasn't thrilled about that but the kit went in fine and the light is 100% better (if not more) than the stock bulb.
I do have a question, since I've only had my 03 for about a month... Is the low beam supposed to stay on when you select the high beam? I didn't notice that on the original buld, but I havent' done much night driving yet. I was wondering if I hooked it up wrong or if that is how it is supposed to be...
Steve
Steve, you did it right. Both high and low light when you select the high beam
1 - 13 of 13 Posts
