1 - 3 of 3 Posts
I have replaced them with good ones. They were reading 9 Ohms on the meter before installation. They don't heat. I checked the fuse it was OK and was replaced with a 7.5Amp instead of 4 A by the last owner. I used the 4 A but still nothing. Can someone provide the electrical drawing so I start from their source? I don't want to remove all the tupperware to find it by chasing wires.
Here is an overview and two close ups for wire colors.
Did the replaced grip set die due to a short circuit? With the 7.5 A fuse, the current allowed during a short would have been nearly twice what BMW intended with the 4 A protection. You may have overheated a wire and shorted it somewhere along the path. You may have to trace the wires from fuse to switch to grip to find the problem. I would do this piece-wise and check for voltage downstream of the switch first and then work towards the grips.
Are both grips failing to heat?
1 - 3 of 3 Posts
