OK just figured out the heated seat seems to have a battery feed and not an ignition feed.Not a good thing obviously.Anyone have a wiring schematic for the seat circuit?No I don't have manual yet.
If it is stock it is on switched power. Center is off forward is high backwards is low. For the front seat is is a two pin connector with a green/brown wire and a brown wire.
Rectangle Slope Font Parallel Pattern
Reactions: kbob12
My seats and grips won't turn on until the ignition is turned on. Are you saying yours do?
Discussion Starter · #4 ·
Thanks.Pretty sure it is all stock.Had the same issue with my Wing when I bought it but it was aftermarket.A Corbin that was wired wrong.I could be wrong though,I've been wrong before lol.
Yeah doesn't matter what position the key is in you can turn the seat on.Didn't try the grips.Should have.
