Does anyone know if the newer zenon headlight assembly will fit in the older LT's, like a 2000 model. They look to be the same size and shape.
2011 R1200RT
They are slightly different, not enough to look different, but enough to not be interchangeable.
Just remember it does not have a high beam - just the Xeon low beam.
Gentlemen, Thank You for the info and speedy reply, but I'm still wondering?
Giles: Is it larger than the 2000 opening? I do have a couple of good dremel style tools. :
John: My concern is for the low beam, as I can add auxiliary lights that outperform the average high beam.
tia
Why not just put in a HID? Lots simpler.
BMW Guru
Absolutely!! I added a high and low HID from CQ lights to my 2003. Much better lighting than a stock newer bike and much cheaper and simpler that trying to retrofit a whole headlight assembly AND having to add driving lights too.
I did the HID over a year ago and while the low beam is much better, the high beam leaves a lot to be desired. If the high beam was horizontal, it would be great, but the vertical beam that searches the treetops just does not get it.
Now the biggest problem is that my headlight assembly looks dark. The only thing you can see is the high beam reflector, so one more reason for a different assembly.
I'm going to tear into the bike this winter so we will see if I can find some way to get more light out of it.
