I took a rock to the head light and need to get a new one to replace the holed one. I didn't even feel it.
Any suggestions. Remember cheap is good. Oh, it's a 2003.
Lewis
Lewis
I have a headlight from a 2003, the bucket itself is all messed up, but if you want to try to unglue my glass and use it on yours, you're welcome to try it. It won't be easy to do, since it's epoxied together, but if you got really creative you may be able to pull something off.
Drop me a PM if interested.
I did some testing on a broken one just to see if the lens could be removed. No way. Mine had a broken lens, and I could not even get pieces out without further breaking them, and even then most of the little glass flange that goes into the plastic was left there. It is a VERY tenacious, probably urethane, adhesive. The glass has a relatively thin flange that goes into a slot in the plastic housing, and that is filled with the very strong, flexible adhesive. It is truly a "one piece" assembly.
Old Slow Guy in A Fast Car
Unfortunately you will have to replace the complete unit. I also had a rock break mine. You can try ebay or beemer bone yard for used but it may take some time. New will cost around $400.00. after you do replace it get you a Headlight cover
Lewis
I have one that was a take off after my '05 was backed into by a truck. The lens is good but I think one of the tabs were broken. I can send it to you and we can work out the details later if it works for you.
2011 R1200RT
Unfortunately it won't fit.
We tried that during a tech session and that was a no-go.
