Well I am looking for some advice once again. The low and high beam are not working once again. I thought I had the problem solved when I check the ground wires on the clip for the high beam. Well the high beam indicator light came on again tuesday on the way home from work. I replaced the low and high beam bulbs and checked the connections as well as the ground wires on the high beam clip and all seems good. Is it time to give in and take it to the dealer? Any help is much appreciated.
