I know these bikes are known for excessive exhaust when cold. It just seemed last time I ran it there was a lot of steam in exhaust. Maybe didn't warmed up enough and it had been a while between starts (1999 43k miles). First I'll do compression and leak down tests. It's probably fine.No but it is not that hard. You do have to remove the radiators, throttle bodies, fuel rail, exhaust, timing cover, cam shafts and chain. I have yet to see one fail but I have removed mine for a re-ring and valve job. What makes you think the gasket has failed?
A primary byproduct of a catcon is water vapor so in cool, humid weather you can get a lot of steam.I know these bikes are known for excessive exhaust when cold. It just seemed last time I ran it there was a lot of steam in exhaust. Maybe didn't warmed up enough and it had been a while between starts (1999 43k miles). First I'll do compression and leak down tests. It's probably fine.
Thanks.
