Can anyone help me? My 02 starts right up when cold but go for a ride, stop for gas and try to start and the engine turn quite a bit before catching. If I don't add any throttle, it just kinda stumbles to life. I've also noticed a poppping sound when you hold the throttle steady at say 2,500 rpm. I did the fuel filter, and plugs at 24K. The bike now has about 27K. Could I be showing signs of a fuel pump or regulator? BTW, I've cut the brown wire as well. Any thoughts?
The Villages, FL
Todd,
This is pretty typical for the LT's. Some say that the fuel vaporizes in the fuel rail when hot and the engine off for a few minutes and that the bike has to "reprime" the injectors. Usually, with my LT, if it does not instantly start, I stop cranking the engine, when I recrank the engine it will start. Also I have had success by cracking the throttle some, this seems to help.
I agree with Mike -- crack the throttle as you start -- that tells the Moronic (through the throttle position sensor) to open the fuel injectors a bit more, which seems to help "purge" the fuel rail a bit faster.
I don't know whether fuel vaporization is *actually* happening, but the throttle cracking works, so I'll stick with this explanation for now! :)
Discussion Starter · #4 ·
Thanks guys. Just glad to hear that others experience this as well. I'm OK with cracking the throttle a bit.
Thanks again,
afastchief said:
My LT did the same thing--the battery was slowly dying, replaced battery and all is well
Thanks for the input! FWIW, I and others found this to happen in hot whether with a good battery -- the problem isn't slow starter (starter spins plenty fast, it just won't catch).
The other day I went for a quick run to the corner store for a gallon of milk. 225 miles. (Didn't say what corner, or which state for that matter. :D) Got back, parked on the center stand, took off helmet and jacket, cleaned the windshield and fussed over a few mindless details. Went to check the mileage on the trip computer, turned on the ignition. switch and the fuel tank started to boil. Stopped when the fuel pump had completed it's pre-start cycle. Hmmm......... Turned the switch off and then back on and the same boiling happened again. Well, I'll be............ Course it was nice and quiet in the shed so it was easy to hear. Off and back on with the switch and it did it just a little bit. I wonder.............. Hit the starter and it fired right up. How bout that............. Usually cranks a bit when it's hot. Must have purged the vapor from the fuel rail. Did anybody mention that when it's hot it helps to crack the throttle a bit ?:)
Went into the house and was "reminded" by my wife that I had forgotten the milk and this time she was coming with me to make sure I didn't forget it. 110 miles this time, and the tank would still "boil."
Suppose we could say this problem is a direct result of BBS?;)
