Super Moderator
I own a 2009 LT and had installed on it a Hannigan SP2 Sidecar in March of 2015.
The sidecar gets a 95 out of 100 for quality, fit and finish. Only issue is a poor fitment on the hatch in the back and the inability to lock the lid on easily.
The attachment to the LT however gets a 50 out of 100 - fail!! I have an extensive list of installation issues, errors and poor craftsmanship. I essentially had to take the side car off the bike and reinstall to make sure that it was safe and secure. I did not bother to complain to Hannigan but did photo document and correct all issues. Essentially it appears to be poor quality control and not having work checked.
At the time of ordering I was contemplating having the sidecar installed just south of Minneapolis by one of their certified installers however the factory told me to get it installed in Murray, KY since they had better LT experience.
Overall we are very happy with the sidecar rig - here are a few of the items that was ordered on the sidecar:
- Open concept with soft side windows
- Spoiler with brake light
- Seat belt
- Steer Lite kit (a must have)
- Did not have the blower fan installed (received a credit)
- Color matched paint job
Already had Wilbers on the bike so I did not need to upgrade the shocks.
Added:
- LED interior lighting in trunk and front interior - their trunk light is old, tired & junk
- Powerlet on the dash for charging
- Power connection on the dash for USB charging of mobile devices - phone, GPS, iPads
- Connection to the AutoCom intercom system
- cup holder
- A Shinko SR741 Series Tire - 130/70-17 rear tire on the front, it fits with no mods
Lots of trikes and sidecar guys are using this tire for several reasons
Issues:
- The trunk lock is also old and works poorly.
- The lid requires redesign as any amount of rain it leaks - it leaks a lot
I use black Gorilla Tape once rain is upon us . . . to seal things up!!
- Last item that bugs me is that the sidecar rides at a slight tilt
Once I have more time on my hands I will correct that as well
Reason we got the sidecar was that my pillion rode on the back of an LT since 2003 and we finally looked to improve her riding experience now she can sleep safely, prepare food for both of us, read her iPad and Facetime with the kids, and bundle up when its get cold, rainy or windy and ride for very long distances with no issues!!
In the future I may convert the rear tire to a car tire but I am not putting enough miles on it to justify!!
To remove sidecar from the bike all you need to do is remove is 4 bolts, disconnect 1 hydraulic fitting and 1 electrical connector. Do not plan on riding the bike unless you also remove the Steer Lite hardware and connections of your brake lines up front but that would be fairly easy - it just takes time. Their hardware is an aluminum plate and taking that off and on may wear out the taped screw fitting in the plate.
Below is a list of questions I sent to Hannigan, after reviewing feedback and other sources I could find. The response from their production manager follows each item from my original list. Any feedback would be appreciated...and thanks for your inputs again ! Ride safe, Jim
I have a few questions based on current owners remarks of the SP Sidecar, if you could provide answers that show Hannigan has addressed these issues with the unit.
1. poor fitment on the hatch in the back and the inability to lock the top lid on easily.
Nothing has changed with the hatch or lid, as this is the first complaint I have heard of this issue.
2. The attachment of the sidecar to the LT however gets a 50 out of 100 - fail!! I have an extensive list of installation issues, errors and poor craftsmanship. I essentially had to take the side car off the bike and reinstall to make sure that it was safe and secure. I did not bother to complain to Hannigan but did photo document and correct all issues. Essentially it appears to be poor quality control and not having work checked.. (This comment direct from a recent new owner)
I would like to know the name of this customer and find out where he had the sidecar installed. If there any pic`s of these issues I would like to see them also, so we can address this issue as to not let it happen again.
3. Is it true that not all dealers have adequate knowledge, when working with the BMW LT. Knowledge that the dealers poses depends on the amount and the frequency of installs they have done. and that Hannigan recommends coming directly to KY factory for sidecar installations to the BMW LT..
Yes if at all possible we recommend having the install done at the factory.
4. Is it recommended to upgrade from factory shocks on the LT, before installing/using the sidecar.
Yes
5. Is trunk and interior LED lighting up to date technology, or old school, low output units.
Old school
6. Has the trunk lock issue been addressed.
What are the issues that need addressing?
7. Has top water seal leakage issue been improved, some users have reported using tape on outside, after closure, to seal against leaks during rain.
In the past we have had issues with the roof leaking. We have worked diligently to improve the seal of the roof. As of now it appears to not be an issue.
8. Some have reported a tilt of the sidecar, which requires modifications to correct to level ride, after installation from authorized shop.
I’m not sure what your meaning or amount of tilt is related to the sidecar. When we install the car to the bike a quarter inch of tilt is set to the sidecar, this is normal. Also the bike is tilted 2* to the left for handling.
