Here's an odd one. . .
After riding for a little while, say thirty minutes, I noticed that the rubber grips have begun to slip outward from the handlebars. One time they worked better than a half inch outward in less than an hour. It's not like they are loose, and I have to really work to twist and slide them back home.
Anyone else have this problem? Never had it on my H-D, but I recall it happening from time to time on my Yamaha V-Max bikes years ago.
Ideas?
Can't recall ever hearing of this issue before. But if this happened to me, here's what I would do. Buy a small can of hair spray (i.e. Aqua Net). The next time the grips slip down, spray some hair spray onto the exposed part and slid the grips back up. You'll be amazed how good that stuff holds once it sets. Just don't use too much.
Yeah. Remember all of the "Beehive" hair do's? Superglue couldn't have done a better holding job on them :histerica
The rubber part of the grips splits pretty easily, but for the LT, BMW only sells the entire unit (heating element, grip), so if (when) the grip splits, you can peel off the rubber part and slide on an after market grip for a fraction of a replacement grip. If it isn't glued on, it will slip off as you describe - especially if you have the heat on DAMHIKT.
But what ever would I do with the leftover whatever that H-word is spray? Haven't seen or heard that word, or the stuff it refers to, on my head for many years. :histerica
I had this exact scenario with my right grip recently wanting to slowly inch back off the bar.I would turn the heat on to get it to slide back up the bar.
I had used Dave Dragon's idea from STC I to put the Wilson tennis racket grip tape on too to solve the splitting problem I was having + to have a larger and softer grip with no "black stuff" coming off on my hands from not wearing gloves.
OK.....the solution to your problem: Jack (cccpastorjack) showed me a trick on using compressed air to "blow up" the grip such that you can get it off the bar entirely without further damage to the heat wires etc. Then you slime "gorilla snot"....that's what they call the window stripping adhesive at the auto parts stores....all over the bar and slide the grip back on.
I bought a new $2.46 Wilson grip tape at Walmart and the grip is now fully seated with a new tape cover and IS NOT coming back off!
Ideas?
Yeah I had this, going on. I think it was mostly because of laziness on my part.
I have the wrist rest on both grips, I think from letting my meathooks just hang on there, it put outward pressure on the grips.
Now that I am aware of it, It does not happen because I also think my grip now.
It was weird!
Rock
