1 - 20 of 23 Posts
(Now THERE's a troll of a thread title for ya!)
Hello, my name is Ron and I have dropped my LT.
I really did "have to lay it down", once she started to go over there was nothing I could do but try to make it as gentle as possible. It happened exactly where and how I always knew it would, if it was ever going to.
It was a pretty typical scenario, the side exit from the 7-11 where I get my morning coffee is a down-hill ramp which meets a road that is also down-hill...with the two slopes 90 degrees from each other. I have always been careful there...careful to stay toward the center of the exit, careful to keep the front wheel straight until I make the transition, careful to never let the bike lean to the downhill side when I did have to stop there.
Not today, today I violated all 3 of those carefully designed anti-dropping rules.
There where several cars coming in that crowded me to the right side.
I had to move right in response as I started down the exit .
I had to make a low speed turn to the right to do so, so the bars were over too far.
There was traffic turning onto the road as I rolled down the ramp...I had to stop.
The inertia of the stop with the bars over to the right started the lean-over.
I put my foot out and the ground wasn't there.
By the time I had slid off the seat enough to get my foot planted she was overbalanced.
Once she was overbalanced...well, you know the rest already.
The truly ugly (and now a bit comical) part is that the bike went over to the right onto a fairly significant downslope. This meant a particularly difficult angle to lift her from, when I tried the butt-into-the-seat trick I found I couldn't get any traction to start the lift...she was down as solid as an 800lb block of granite!! YIKES! Luckily a couple of samaritans showed up after about 30 seconds and helped me get her to her feet. Now I found myself standing on the right side of the bike, downhill, with the seat about waist high! Even if I had been able to get her up by myself I doubt I could have gotten back on...and, I don't know if you are aware of this, there is no kickstand on the right side! My only option would have been to try to walk it down the hill and around the corner to where it would have been pointing downhill on otherwise flat ground. Then I MIGHT have been able to get on without dropping it again...this was decidedly not good. Fortunately one of the guys who helped me get it up stuck around long enough to keep her stable while I re-mounted...a big hearty thank-you to both of those guys!
So, that's 2.5 years without incident until now...that top-heavy b#^ch finally got me. I was going to take my Vulcan to work this morning but I had the bikes parked in the wrong order in the garage and didn't feel like playing musical motorcycles at the time...too much bother ;). Had I been on the Vulcan this whole story would have been about how I had to plant my leg out a tad further and wrench the bars back...it would have been about why my shoulder was a little sore instead of my back...instead it's about the only things about the LT that I really, truly, don't like...the high CG and the seat that's just too damn far from the ground. :(
Welcome to the club !
I've only dropped mine three times so far. :)
First two times in the first month of ownership..
Third time in the "box" at the ERC. The wind was blowing about 40 mph and a gust just slammed me to the ground...:mad:
Oh well. That's the price you pay for having one of the coolest bikes on the planet..
Three times for me as well...
First time after 1 hour of ownership.:eek:
Second time after 1,5 years, jerking it off the centerstand on a soft gravel
And third time (after 2 years) which really could have been good food for the candid camera:
I was opening my electrical wrought iron gates with my remote control, got them opened and drove between them and I was going to open my garage door. Pressed the wrong button on the remote and the gate started to close and pushed me down...:mad:
Regards
find a new spot to get coffee. that sounds trecherous.
Actually they have a front entrance/exit that I will now use whenever I'm on the LT. It involves an extra right turn at a traffic light. The side exit opens onto the road to my neighborhood and avoids the main street and lights...clearly the better choice when astride the black beast!
1st thing to do after she drops on the right side is to extend the kickstand, place her in first gear (If at all possible).
The kickstand is obvious, 1st gear helps keep her from rolling away from you if your hand slips off the front break, or don't have enough brake pressure built up.
BTW, welcome to the club !!
Clearly I am not a master of the obvious!!! What a brilliantly simple thing, it never even occured to me...doh! Of course it has been over 12 years since I've put a bike on the ground! That time it was a gen1 Yama Venture 1200, very similar to an LT...but lighter ;). Almost the same circumstances except in front of a bunch of girl scouts, I was so embarassed that when I picked it up I literally tossed it right over onto the other side! I guess I just wanted matching sratches!
3 times myself also..still come close occasionally when I don't pay attention to the situation..all on the right side and I remembered the sidestand and 1st gear trick after the 1st time..
It's still the best bike I've ridden..
Ron,
Thanks, man. I'm amazed you held out this long. I've had my LT for 7 weeks and she's been down...ouch...3 times. And like Ari, one of those drops was in the first hour of ownership. Hard to admit it, but it's reality. I guess there's a little consolation for me in knowing that, having performed with no style or grace the infamous "850 lb. drop", I'm in company with many of you experienced and respected LT'ers who've also had the misfortune of doing it...and I'm not ever gonna let it discourage me 'cause she's too danged much fun when she's upright. I'll just learn from the mistake, pick er up, yell at her for being so stinking overweight, apologize for the drop, re-mount and GO! Yeehaww!!!
(BTW, BMW, I'm grateful for the crash bars.)
What kind of damage is typical from a "drop"?
My '04 LT is 'in the mail', so a new-owner-to-be is just curious!
Discussion Starter #12
This morning's fiasco resulted in a very minor scuff on the underside of the front right "tip-over-wing", it is also popped slightly out of place so I have to loosen a couple of screws and push that pesky front tang back in it's slot.
It also caused a somewhat more disturbing ugliness to the chrome-like saddle bag guard (also the right side)...as luck would have it there is another thread from this morning that pointed me to those nifty rubber-baby-buggy-bumpers...a $30 fix that saves me from doing an R&R on that shiny plastic doo-hicky! :)
32oz Big Gulp was the deciding factor
I had a zero mph drop in a hotel parking lot. Also on a steep incline. I'm convinced that the 32oz drink in the cup holder was the straw that broke my back. Had that thing not been there I probably could have held it.
Discussion Starter #14
Sounds perfectly reasonable to me. I had a spare FF helmet in the right bag, the left was empty...that HAD to be it! :p
Hi Everyone
Haven't owned a bike for 23 years. The last one was a 1961 BSA Rocket Gold Star. So I thought time is running out, it's time to get back on a bike. So I liked the look of the LT and my wife kept saying that I was to old. I thought that if I bought something as big as an LT I couldn’t possible have a mishap. Within 2 days I had dropped it at a slip road. It took me and three bystanders to pick it up. I went into work the next day joking with my colleagues that I had joined an exclusive club; little knowing that one actually existed. So hello from the UK. Any handling tips welcome.
Regards
Dave
Actually I think the LT world is made up of two types of people. Those who admit they have laid it down and those that don't admit it. Welcome to the club. You drop it a couple of times and you learn fast. It is not to often that you want to have to pick it up. It is a heavy sucker.
Welcome
Regards
Ari, was this during your Learning phase of the 350,000 switches on your bike? :D
I will get to that file of your rack probably Sunday evening or Monday evening. I work a deadmans shift this weekend, 1p Sat-430p Sun :sleep:
UncleRock said:
Now you can ride it without worrying about it. She is no longer a virgin :D
Rock
Rock,
Yea, mine was deflowered in the garage, but I didn't have 3 bystanders to jump in and help me...so it was Just me lifting that pig.
I have since bought a treadmill for her, and she runs on it in the garage daily.
Welcome to the club
I dropped mine twice while not even on it, after several months of ownership. Both times it was on the center stand, on the slightest of downhill grades. First time, I pushed it ever-so-slightly forward and down it goes. Second time my wife was dismounting from the rear seat and her motions moved it off the center stand and down it goes. We're both members of DA now! ;)
"Ari, was this during your Learning phase of the 350,000 switches on your bike? "
Bill, that is too damn funny!
Ari... welcome to the club! Just thank your stars that nobody was hurt... except your pride and your ride.
Don't feel bad!
The first two weeks I had my LT it was on its side twice. Both times I was attempting to put it up on the centerstand. I didn't know the "secret" for this process. With assistance I was able to right the bike. Scratches on the chrome strip on the saddlebags. Other than that, all is well. Learned the process of putting the bike on the stand (still isn't that easy) but level ground and I have become best of friends!
1 - 20 of 23 Posts
