Disconnect the 911 unit and then pull the ECU fuse for 20 minutes. Then replace fuse and manually set the TPS limits by switching the key on (don't start) and open and close throttle twice, key off then try to start. The bike will always show a hall effect fault since the engine is not running when you hook up the 911 unit.
