1 - 13 of 13 Posts
I'm removing my BMW Navigator to replace it with my Garmin 2610. Other than the BMR shelf, are there any options similar? I don't like the Ram mounts, I want it in the middle.
Discussion Starter · #3 ·
Deacon, can you be more specific as to where it is, or which section to look in?
The Villages, FL
BMW should still carry the older mount for their first generation GPS units. This is a bracket that went through the map light socket. I am at work so I do not have a picture of the mount.
The Villages, FL
Here are a couple of pictures of the BMW mount. The mount is different from the SPIII mount that I had. I had to install longer screws for the bracket. the actual mount came from BMW, where the "bracket" for the 2610 came from Garmin (motorcycle kit).
made my own cost $30.00
I just drew it up on cardboard using the gps for size then folded it up after I was happy I just took it to a metal fabricator who bent it up in 3mm aluminium charged me $25.00 i got 3 rubber nuts from fastener shop and there you go just wired it to the map light as per all the great sugestions from this site
yep that dam reflection has been irritating me for years and it was worse after the tinted screen went on alls good now :D
Touratech
Gets it right up in front of you
1 - 13 of 13 Posts
