I installed a Givi top case with the break light option. I inserted the connection piece in the top case that has the two metal connection cylinders that protrude out a little bit to make a connection with the flat connection piece that installs in the support rack. I inserted this piece into the case from the inside of the case and the connection cylinders are about 1/32 of an inch recessed into the case. They do not make contact with the support rack piece. The directions stopped at the part were you install this piece and the wire it to the bike.
I too the top case off the bike and put it on its side on the back seat. I held some wire to the connection piece on the case to the one on the rack and the lights worked so it is defiantly a bad connection when the top case is mounted on the bike.
Question, are you support to insert the connector that goes in the top case from the inside of the case as I did?
