1 - 12 of 12 Posts
Now guys, many of you have gone "deeper" inside the LT as I have just concentrated on the farkleizing business, so some advise would be appreciated:
Some time next week my gearbox will be changed due to the skid plate touch down I experienced last week. http://www.bmwlt.com/forums/showthread.php?t=25585
The work will be done by the dealer and the insurance company will cover the cost of the new tranny + labor. Now that the drivetrain is all apart, what all things should I ask for the tech to carry out on my expense?
My clutch feels OK , I think. It could be just reading too many horror stories about slipping clutches that I have sometimes had a fraction of second feeling that my clutch is slipping. It´s probably not. I guess a professional tech can see the condition of the clutch if I ask him to do so. Will the clutch become visible when the gearbox is pulled out or will need some extra effort to get into? Of course now that I will be riding my bike to the dealer about 150 km distance I could of course do some hard accelerations and see if the clutch has any slippage symptoms...
What about the famous slave cylinder? What all parts would you change just as a precaution? Yes, the weep hole will be drilled!
In last service my tech noticed a very small leak which seemed to come from the seal between the gearbox and the engine. This leak is very minimal as so far I have not seen a single drop of oil on my floor. Just enough to keep the bottom of the engine and gearbox kinda black and messy looking. So I hope this will be fixed automatically.
The rear drive bearing could be changed as well, I guess. Or am I suffering of paranoia?
Anything else?
My bike is manufactured in Dec. -03, it is the '05 model as you Americans call it. It has 66.000 km ( 41.000 miles) on it.
Thanks for the input in advance :) .
Regards
Ari...
Have the engine output shaft seal changed. Ask that they verify the crankshaft(engine output) shaft is not damaged (Standard repair proceedure)... just ask... =)
Also, it is konw that the Slaves "leak" over time... could be normal to "weep" as you're seeing between engine and gearbox.. but I'd have it replaced "while in there".
Your personal wrench guy should be able to tell you how much of the clutch is 'worn' away. If you're planning to keep the Farkle Platform, Sunset Cruiser II, then decide. For me.. replace the Clutch and Pressure plate and Flywheel whenever you replace the "clutch"... There is very little risk that the "clutch" assembly will fail.... but ask your wrench if that would be a "warranty" coverage to replace if it fails.
I would definitely "drill" the weep holes in the Slave and Gearbox. The only difference being I would bring a "plug" of some type for the clutch area since your environment tends to be a bit damper than some... I would then pull the plug at my oil changes... and keep an eye on oil dampness around it... a sign of problems...
Hi Channing and thanks for your advise.
Just to confirm to you and others as well, that yes, I plan to keep this bike for quite some time yet. I can consider getting a new one maybe one or two years after BMW introduces the next generation LT. I let somebody else do the pioneering and test rabbit thing...
In the "worst case" I still ride this bike to CCR 2011 where ever it will be located. (Any hints..?) I try to make it there with my wife this time.
I still have a question: I know about the slave cylinder weep hole but what and where is the gearbox weep hole? I think I just made one by myself but that was not a success..:p
Best regards
When my '02 was apart for a new clutch caused by leaking engine seal, after consulting with the service guys, I had all the seals in the engine and trans replaced, a new clutch slave master (the redesigned part), and the weep holes drilled. Due to the cost you don't want to have to back in there for a long time.
Ari, try this thread.
Dave
Best regards
Hi, Ari -
I think Channing is referring to the clutch housing/casing - not the 'gearbox' or transmission unit. Slap me if I'm wrong, butt don't tell Channing!!! ;) Good luck with your 'project', Ari --- I know you'd rather be farkelizing instead of 'repairing'!! :(
Best Regards.
Ari,
Glad you asked.. and Dick gave you good info... do NOT put ANOTHER hole in your GEARBOX.. DOH!!!
I was indeed speaking of what automotive folks call the "bell housing" which is where the clutch resides. This area is exposed to the GEARBOX input shaft and the ENGINE output shaft (crankshaft).
With a small (2mm) hole drilled at the bottom (6-o-clock position) of the the BELL HOUSING's lowest point, fluid should leak out rather than contaminate the clutch. Of course ANY leak there is "undesirable".... Cars typically leak at the rear main seals without damaging the clutches... so I can only assume the design of the LT allows the fluid to be spun around inside the bellhousing rather than leak out...
Hi Dave and others,
thanks a lot, that was a very good and informative thread! Now I am pretty much on the map again.:)
I 'll keep you posted on how things proceed and how many holes in various locations we end up drilling:p .
Best regards
Update on the new gearbox
My bike has been at the dealer for about two weeks now waiting for the new gearbox and time from the technician to tackle the project.
Today I received some pictures of the project and also a request from the wrench to come up and help him putting the bike together. He got somewhat lost with some of the extra wires and connectors...:p
No problem with that, I actually offered to come and help him as usual.
He also explained that the new tranny came complete with a new slave cylinder but he drilled the weep hole in the housing anyway.
he also drilled TWO inspection holes in the clutch housing. One in the bottom and one on the top. These upper one is for the borescope inspection.
I have been bikeless now for two weeks and I have been kinda crawling up the walls already. Luckily I have been busy with work related travelling, part of which I could have ridden of course. Especially in the +30 C weather we are currently enjoying..
Updated pictures from the workshop are here:
http://picasaweb.google.com/pozoizquierdo/BROKENGEARBOXHOUSING
Thanks for all the good advise from everybody! Let's hope there will not be many left-over parts tomorrow.;)
Regards
Feel for ya
Ari, your bike looks just about like mine does at the moment...although mine has about 3km less wires...
Did you get any precise measurements on size & location of your inspection holes?
How accessible will your inspection holes be after the bike is all back together? Will it require any disassembly to access? Or will you line up similar holes in every layer out thru the Tupperware? ;)
I'm surprised I haven't heard you describe plans for an onboard video clutch monitor viewed via your GPS screen. :p
Get well soon! ;)
Hi Dave
and thanks for the good wishes!
I have not seen the bike with my own eyes yet. The dealer is about 100 miles North from my hometown. I will drive there early tomorrow with all the parts that I already stripped from it before riding it to the dealer with a leaking gearbox.
I will report more after we have the bike finally together. Now it's getting late up here...
Regards
1 - 12 of 12 Posts
