I am burning about a quart of oil per thousand miles on my 2001 LT (88K miles). So I thought a compression test would be in order to get a sense if one of the cylinders was problematic.
In order to stop fuel entry during the test, Clymer (pg 62) recommends disconnecting the electrical connector at the fuel pump. Would I be able to achieve the same thing by removing Fuse #4 (Fuel Pump, diagnosis connector and Motronic)?
Thanks in advance.
I'm not sure if the Motronic is necessary to activate the starter relay to crank her .....
Ditto cfell, it will work just fine.
