Dale, the RS link that Dick provided is more than adequate for the Fuel Tank and Fuel Filter removal. The differences are minor, such as the fact that your '05 LT will not have the barbs connecting the fuel lines, it will have quick disconnects! Much easier! The pictures are very accurate concerning the Fuel Pump and Filter. Do take note of the arrow on the Filter for proper fuel flow!
Your seat bridge will need to come off as John said, and the long bolt which the article is referring to is one that goes through both the seat bridge and the Fuel Tank. It can be a bear to line up when you go to reassemble, so be patient!
Once you have the Tank off the Air Filter is a breeze with just four Phillips screws holding the lid on. Be sure to check for bugs and particles which can get into the Air Box, and vacuum them out before you replace the Filter.
It is amazing how much money you can save by doing it yourself. More money for Farkles!
dnifong said:
thanks guys. that is great info. Dick, I have a 2005 LT. Do you have that same sheet in the lt version?
thanks again,
dale
