We recently had Hannigan convert our 2007 LT. I am looking for information on the best tire when the front tire needs replacing. I read the long series of posts praising the Michelin Pilot Activ 130/70/17 rear tire mounted in reverse. The comments offered pertained to trikes prior to 2007 models. When I inquired from a BMW dealer they informed me that there may be a problem with the clearance for that tire. I will include a copy of their reply below. I was wondering if anyone has first hand experience with replacing the front tire on later model trikes. There have also been favorable comments on this site relative to the Metzler Bias 880. Pardon if this sounds stupid, but is that a front tire or a rear tire used on the front, and should it be mounted in reverse? Thanks for your help.
Ray
Email from dealer:
Ray,
I think that would be a good choice. It has 2.0MM more tread depth and 64LBs more load capacity than the ME880 Metzeler. It is about 1/4"-3/8" wider on each side though. I looked at another LT at our dealership and there is a bracket underneath the stock front fender that is pretty close to the stock Metzeler, not giving too much extra clearance for a wider tire. You will need to modify that bracket to allow more clearance, unless you already have modified it or if you don't have a stock front fender. I don't think we will be able to modify the fender bracket.
Ray
Email from dealer:
Ray,
