How can I get my Front Speaker Grills off :confused:
I'd assume you have to disassemble the cockpit, which probably means pulling almost all, if not all, the plastic form the motorcycle.
So, I have to ask, why do you want to remove just the speaker grills?
Needs speakers and some paint on the grills ;)
You have to take the plastic part off that the grills are mounted in, the grills have metal tabs around edge that fit into slots then bent to hold them in place.
be careful with the foam that is glued to them... i ended up replacing having to go to a fabric shop cause it was dry rotted
