1 - 9 of 9 Posts
I have an '06 K12LT with 165K and just noticed a slight front end wobble with hard braking. I noticed that the steering damper has some play in it but what else should I check for possible issues. Brakes are good and so are tires.
If truly a wobble, I would suspect cupped tire. If a pulsing feeling, then likely pad imprinting on the front rotors.
Also have a 2006LT but with only 20,000 miles. Recently did the Tail of the Dragon, 2-up and loaded. New BT-020 tires front and rear, steering damper recently rebuilt, suspension in good condition, tire pressure 42/48 psi. During really hard braking into sharp turns I noticed the same front-end "head-shake", sometimes quite strong. Going fast around sharp turns is however not what the LT was designed for, so I guess the head-shake is just a reminder to slow the pace down a little.
It did shake its head with the previous Metzeler front tire when lifting the hands off the handlebars below 50mph, but since I fitted the BT-020 there is none of that anymore, at any speed. The tire has a little over 2,000 miles now, and I expect the shake will eventually return as it wears.
The tire is good with good pressure. I took the tire off and think I found the problem. The two bolts holding the right front shock to the stabilizer were loose. I tightened them and also ordered front brake pads as they are close. Hopefully this was the issue. Everything else seemed tight without oil leakage.
Enjoy The Ride
I've had mine shake so bad the CD would skip under hard braking. Seems normal to me.
I almost hot a moose last year near Dawson City, two up with trailer. I braked so hard the ABS was chirping on the road without head shake. I hope this fixes the problem.
1 - 9 of 9 Posts
