I wanted to let you all know how I stopped my front and rear brakes from making the insane squealing when they are applied. It is so simple.
Go to WalMart look in the stationary dept that's where I usually find them. Some stores will differ. Look for the little 1X1 inch two sided sticky things made by 3M for holding light weight objects to the wall or on your desk. Usually there are 8 or so in a small package.
Cut one of them in half... Take the two little screws out of the little piece of tin that holds the shoes in place on your front brakes... All you need is half of one of those sticky pads stuck right in the center of the tin so that when you screw the tin back on it makes contact with the shoes... noise stopped. Its like a dampener of sorts
Oh ya leave the paper on one side of the square. It will not stick to the shoe and a little WD-40 will remove it from the tin when you change the pads next time.
It worked for me. Give it a try... you own a BMW, 2 bucks wont break ya to find out.
Safe Motoring everyone :bmw:
