So I just recently had my front tire replaced by my friend and local custom motorcycle shop owner. I remounted the wheel and just got around to take it for a spin this evening.
When coming to a stop using the front brake I noticed a strong pulsing and that the brake was very very grabby. I thought maybe there was some grease or contaminant on the rotor and figured I would just clean it up with some brake cleaner when I got home. Once home and under closer inspection I found the ABS ring had a dent in it:
So my questions are, Do you think this dent in the ring would cause the pulsing and grabby brake? Any idea how much a new ring will cost?? It looks like you can replace the ring without replacing the rotor...true? I checked both rotors and they are straight, so looks like just the ring will need replaced.
As for how it happened. I know it happened at my friends shop...I was there when the wheel fell over into the mounting machine. He nor I thought much of it at the time and didnt even think to look at it. It was a complete accident and is one of those unfortunate things. Hopefully it wont be one of those expensive unfortunate things!
