I am considering changing out the front brake flexi hoses on my bike, i have had a couple of occassions of the front brake binding, & i suspect a flexi hose has broken down internally creating a restricted return of fluid.
Can anyone in the UK recommend a replacement, braided would be good.
I have looked at the callipers & checked that the pistons are returning etc.
I acn always get the BM ones, but am not overly convinced of the quality, 2003 & 34000 miles, i feel this should not be happening!!, so would prefer an alternative, once replaced i will post my findings.
Regards
Stevie
katnapinn said:
Stevie I'm not sure if these guys ship to UK but they are the supplier thet we use here in the states.
http://www.spieglerusa.com/cfm/brakelines.cfm
+1 on the Spieglers. Not only the last lines you'll ever need, but will greatly improve the braking capabilities of the beast.
Not the only braided stainless steel ones out there; many have used others, with similar praise.
Just thought i would post an update.
After thinking a bit more about the flexi hoses, i realised that an internal breakdown of the flexi hose, would create a regular & not intermittent fault.
I removed both front callippers to get a really good look, all pistons seemed ok, i did notice some uneven pad wear, these were EBC replacements, plenty of wear left, i noticed 2 of them were firm in the callipper & had to be pulled out, closer investigation showed the wear surface bonded to the metal pad, to be slightly over at one end, i filed them back to the metal pad, when replaced they were a loose fit.
I have ridden the hell out of the brakes, repeatedly simulating the conditions when they got very hot & bound up, & have not been able to get them to bind, i feel that my binding problems were most likely caused by the binding brake pads, these were not returning & allowing heat to build up then binding against the disc..
Feel free to offer differing opinions??
Regards
Stevie
Sounds as if you are on the right track.
When my front line sprang a leak, the braking was still fine, except that the pressure went gradually down.
One person reported removing his flex lines, bringing them to a brake place and having lines made at less than half of what it costs to order them on line.
Best from Tucson
Bob
