How long will it take you to do a FD oil change on the RTLC?I change my FD oil every oil change.
15 minuets start to finish. Everything wiped down clean and put away.How long will it take you to do a FD oil change on the RTLC?
This board is for RT Series (Post 2013). Please post in the right place so as not to fill up the space where it doesn't belong.I decided to renew the final drive oil this week with the bike (2011 RT) only having done 8500 miles. I recently did the gearbox and although the level was a little low the oil was clean. As I drained the final drive the oil was very dark green grey. There was iron residue stuck in the magnetic drain plug too. The level was correct at 180mls and was replaced with the same amount of clean final drive oil. I suppose my concern is the very dark oil and metal after only 8500 miles. Is this normal after such a short time on he road?
Also, when the wheel was remounted and off the ground I turned the wheel by hand with significant 'play' experienced moving it forward and back. There was a slight clunk too. I would have thought this was not good but it may be that this is normal. Is it? Any guidance as to what might be done to reduce the amount of play, whether it is in the final gear, the shaft splines or the gearbox, would be helpful.
If you look at the dates on the original post (that you quoted), you'll see that it was from 2015. 6 years or so before the RT Series were split between Pre Wethead / Post Wethead. Recent replies brought it back to being active...This board is for RT Series (Post 2013). Please post in the right place so as not to fill up the space where it doesn't belong.
My info for previous’06 RT was 180ml; assuming still applies to 2014+ bikes?15 minuets start to finish. Everything wiped down clean and put away.
It does. My 2016 RT and 2021 R Nine T both take 180 ml in the rear drive.My info for previous’06 RT was 180ml; assuming still applies to 2014+ bikes?
Thanks for the reply and confirming.It does. My 2016 RT and 2021 R Nine T both take 180 ml in the rear drive.
Don't confuse the dry clutch (up to the wetheads) edition RTs where the critical lubing was for the gearbox input shaft splines.Interesting. With my previous ‘03 R1150 and ’06 RT, every dealer and independent shop mentioned the necessity to lube the splines
/\ /\ What he said.Not a good idea to use a 140 weight gear oil in the final drive. There are many discussions on another forum by a life long BMW technician who knows more about these bikes than the BMW service technician. That was brought up and he did not recommend it. The gear box is no problem since it will solve some issues with noisy shifting, but not the final drive. Stick with 75w90 for the final drive. Hexheads and Camheads. The newer boxers use a slightly different weight gear oil that is difficult to source unless you buy if from BMW $$$$$$.
The dealers in my area don't even use that BMW G3 oil. They use the same one that was used beforeNot a good idea to use a 140 weight gear oil in the final drive. There are many discussions on another forum by a life long BMW technician who knows more about these bikes than the BMW service technician. That was brought up and he did not recommend it. The gear box is no problem since it will solve some issues with noisy shifting, but not the final drive. Stick with 75w90 for the final drive. Hexheads and Camheads. The newer boxers use a slightly different weight gear oil that is difficult to source unless you buy if from BMW $$$$$$.
