1 - 2 of 2 Posts
anyone try to see if there is an aerospace bering or better type of bering that will retro-fit to a k1200lt, 2000? With all the different berings out in the market, Is there a better one that will hold up to being mis-shimmed better than the current one? Food for thaught?/
Myself and other engineers have looked into that in great detail, but there is no available bearing on the market that will fit without MAJOR re-design. The bearings used are already high quality bearings made by major manufacturers (FAG and SKF). It does not seem to be a bearing problem anyway, but likely an installation issue at time of final drive assembly. Improper shimming, or improper application of installation pressure both likely suspects. Chasing the dream of a "better" bearing is nothing more than wishful thinking.
1 - 2 of 2 Posts
