I thought I would share a few tips of how I install the FD & align the drive shaft U-Joints.
The first thing I do is to rotate the drive shaft so the front U-Joint is in the 12,3,6 &9 o-clock position. I then put it in 1st gear & mark the shaft at the 3 o-clock position. Then I install the rear U-Joint aligned with the front U-Joint & mark every thing with a paint stick. I also mark the rear U-Joint cap at the 3 o-clock position.
Now I install the rear U-Joint & spline into the FD & rotate the marked cap to the 3 -clock position & lock it in place with a c-clamp & a spacer or washers between the brake rotor & the rear brake caliper bolt hole.
I now can install the FD & keep everything in alignment . Look for the painted U-Joint cap thru the right pivot pin hole. After the pivot pins are in place & the rear reaction bolt is installed I remove the c-clamp & rotate the rotor to make sure the drive shaft is engaged to the FD. If the rotor rotates the FD is not engaged into the drive shaft.
Now follow the torque specification's to finish the FD install.
