Greetings all.
I've traced a fault down to my seat-heat switch. You know, the black, three way one just off to the right down low on the front seat. Now, is there a way to pull these apart to check for internal problems? It's a simple three way switch, how hard can it be?
Cheers to all
Paul Harrington
AU
Paul,
It is not a special switch. You should be able to pop it out of the seat and may even be able to take it apart for inspection/repair. It is just a single pole, double throw with center off.
You can just unplug the cable! if you do not need it.
harrowbmw said:
Greetings all.
Cheers to all
Paul Harrington
AU
Oh god....springs...no one mentioned springs! Thanks for the warning Jim. I'll tread carefully.
