I have read everything I could find about the exhaust studs, and only confused myself even more.
I bought 8 new studs and 8 new nuts from Bob's yesterday, and they are ready to go in.
* Do I use anti-seize, oil, or anything at all on the stud, specifically the part that threads into head? (all recommendations I have seen)
* Or, do I use threadlocker, loctite, etc, on the stud to keep it from ever coming out again? (seen these recommendations as well, in contrast to the above)
* Do I bottom out the stud in head? (some say yes, some say no and to leave a gap.)
* I know about the 22nm or 16ftlb torque, but that is listed for the nut, not the stud itself, so that is my biggest question. If I obviously thread the stud into engine first, I need to know what kind of torque I'm using. Clymer manual says on page 258, step 13 e. "If a stud was removed from the cylinder head, separate the stud and nut and reinstall the stud into the cylinder head. Refer to Service Methods in Chapter One." Pg 20, in Service Methods, under Stud Removal/Installation, says use threadlocking compound, and step 8 says "Install the stud to the height noted in Step 1 or its torque specification." I didn't measure the height, and they were all not the same anyway before I took them out.
Ironically, the copper plated nuts (plated to prevent seizing) I attempted to remove were fused with the stud and the clean, dry stud threads in the cylinder head slid out with minimal effort.
Any and all advice, tips, thoughts, etc are welcome. Please stop me before I just use my impact wrench to seat these things. (I will record video for that if it happens)
