That's within the neighborhood I was quoted a couple years ago, and why I did it myself. $2,800 is within the realm of "reality" for an LT clutch job at your local stealer.
In Socal, $2300, but that was for everything, rear seal, imput shaft seals, clutch, slave and new seal for bell housing.
Discussion Starter · #5 ·
I called Hermy"s for a ballpark figure they gave an estimate of $900 to 1200. So I towed it 140 miles. They took it apart and said it would be 2800. For the average clutch job. Now that they have it apart $500+ so far. Now nobody remembers giving me $900 to 1200 estimate. See how easy they make it to hate dealers.
Discussion Starter · #6 ·
Anybody coming by Baltimore,Md anytime soon with clutch replacement experience I am buying lunch, and beer for as long as it takes.
Super Moderator
I replaced the rear seal on the engine which required taking everything off including
the clutch.
The job was time consuming and simple.
Did this by myself without a bike lift but you should have a lift to hold up the back of
the bike. The videos by John Zeiler and the PDF mentioned earlier was all I had to go
by with an occasional look at the Clymers Manual . . . :D
Only undocumented issue (or maybe I just did not read it well) was taking our the rear
engine support bolts and dropping the rear of the engine to get the transmission out
while loosing the front support bolts.
Also had the special socket (milled out) and the large allen wrench for the swing arm
and made my own piece of angle iron to stop the clutch from rotating when torquing
up the bolts
Make a few mistakes - like messing with the transmission reversing switch. Had to
buy a new one!!
Actual wrenching time about 20 hours, actual thinking time about 20 hours, actual
ordering parts and waiting for parts about 20 hours.
In the end and looking back this was not a complicated job. This is nothing more than
nuts, screws and bolts job and getting your sequences in correct order and making
sure the wiring gets routed and connected back properly. No special instrumentation
other than a torque wrench is needed. No bolts were broken, seals destroyed or
knuckles smashed in the replacing of the seal. Also drilled the weep hole for the clutch
slave cylinder.
I understand why a dealer wants large sums of money - this job is time consuming!!
My parts costs were minimal . . .
I was going to offer to come to Howard's to jump in however it looks like Howard if off
to the wild blue yonder or should I say - someone is going hit the road and will be
working in the near future!! :(
Beemers Uber Alles
9248 Mike Garcia Drive
Manassas VA 20109
George @ 571-318-2472
http://beemersuberalles.com/
You will find George to be very fair on prices for service and very knowledgeable.
