I am replacing rear engine seal, is there a run out spec for the rear engine shaft, if so, what is the measurements, if so how is it adjusted? I also noticed that there is about a 1/4 turn on trans input shaft before it is felt on output shaft with tranny in gear, is this appropriate or not, BMW manual I have doesn't give a lot of info, is there another manual offered? I say "Thank You" for any and all help.......Sgt, 2000 K1200LTC, 90,000 miles
Me, too
I'm also replacing my rear engine seal this weekend - sounds like you're a few steps ahead of me (I'm still riding this week). I'll be very interested in how your job turns out.
BTW, are you using the BMW clutch housing bar or did you make your own? Any prints or plans for homemade custom tools? (already have the 30mm socket).
Sgt I noticed the play this past winter when replacing my RMS. I moved on and finisged the job don't worry .
Play
Which play are you speaking of: play in engine output shaft, or rotating play on tranny input shat to felt output shaft?
Terry Simpson
Sgt
Terry,
Would be nice if some more folks chimed in on this one. FWIW, my engine shaft had lots of radial play in it as well - I kinda expected it to be rock solid, yet you can deflect it pretty easily.
WOW, what a PITA to get the main seal out!!! I didn't have the official seal puller, so I cobbled together a variety of "tools" made from bent nails, vise grips, even pushed a 2" long steel dowel thru the end of a small diameter pipe in a "T" shape, got the dowel into the seal and whacked a vise grip clamped on the pipe. All the above simply managed to chew the seal into oblivion, until I finally got a vise grip clamped directly on a piece of the seal itself, and was able to pull it out that way.
I hope the tranny seals will be easier.
Haven't looked at the tranny in/out play yet.
Dave
"I hope the tranny seals will be easier."
Dave
I found removing the tranny seal (clutch side) to be more difficult. Puncturing the seal with an awl, ala the manual, just pushed the seal in farther. I finally got it out by breaking the metal band built into the seal, but it wasn't easy and I risked scoring the aluminum. Thankfully it looks ok.
If I were doing it again, I would mark the center of the seal ring with a tap from a sharp point, drill a 1/16" hole through the seal's metal support, expand it with a 7/64" drill, then use the smallest screw extractor to grab the seal. You may need two grab holes at 180, but I don't think so.
I tried this method on the old seal in the vice, and it extractor gets a good hold. Be sure to hit the center of the seal wall or the drill will drift into the rubber only part of the seal.
I decided not to replace the tranny output side, even though I bought the part. It's not leaking and I can replace that one later, if necessary, without removing the transmission.
Good luck
Richard
