Electrical connectors? Do you mean Oil pressure and engine temperature sensor area in the left/ front engine?
I used to run my oil level at the top of the sight glass. At about 155,000 miles I had minor oil leaks on the front & back of the engine. The clutch finally started slipping. I lowered the level to just below the center of the sight glass. I now have no more leaks & the clutch no longer slips at all. It did take about 2000 miles of easy riding to get the clutch to stop slipping. Last weekend I was back to wide open throttle in the mountains up to red line and had no clutch slippage. I now have over 160,000 miles on the original clutch.bigbear said:On this engine design you would have to do a major overfill to start damaging seals. .
LOL! bigbear wrote CRACK SHAFT! Sorry, just finished writing four final exams about 4 hours ago. Feeling just a weeeeeee bit giddy!bigbear said:On this engine design you would have to do a major overfill to start damaging seals. The crank shaft is several inches above the normal oil level so there is a significantly decreased decreased chance of crack shaft splash creating excessive pressure.
I believe you Dave but I can't explain it. If you look at the oil level with the engine off it is below any seal in the engine even at the top of the sight glass. When running the oil level is below the sight glass. How does that contribute to a seal leak? Am I missing something?saddleman said:I used to run my oil level at the top of the sight glass. At about 155,000 miles I had minor oil leaks on the front & back of the engine. The clutch finally started slipping. I lowered the level to just below the center of the sight glass. I now have no more leaks & the clutch no longer slips at all. It did take about 2000 miles of easy riding to get the clutch to stop slipping. Last weekend I was back to wide open throttle in the mountains up to red line and had no clutch slippage. I now have over 160,000 miles on the original clutch.
Could a lower oil level help while running if the rear o-ring is bad.jzeiler said:I believe you Dave but I can't explain it. If you look at the oil level with the engine off it is below any seal in the engine even at the top of the sight glass. When running the oil level is below the sight glass. How does that contribute to a seal leak? Am I missing something?
