I have a question. I have an 06. do lts have noisy valve train. at 2000 to 3000 rpm there is a tapping noise and like a loose valve. If I pull the clutch in and rev the engine up and down between 2000 and 3000 I can definitely hear it tapping. cant seam to hear sitting still. to much other noises (vibrations )
I've heard this and asked the same thing. Folks 'round here have re-assured me that it's NOT THE VALVES, but rather the injectors making that noise.
Only assurances I have are these folk's reputation and fact I did my 12K valve check and all was OK then. 160 miles to 24K, guess what I'm doing again soon. <g>.
I have an 05 LT and it has the same clacking/valve sound at 3000 to 5000 rpm and it did this before and after a dealer valve adjustment job so it really may not be the valves.
Normal. Turn up the stereo.
Also the valves wear tight (seat wear) as opposed to loose (cam and follower)on the LT. If they wear loose you have a serious problem.
It's the injectors, and can easily be proven.
Disconnect all your injectors, and the noise goes away.
