Hi all,
Does any one have any advice on my 2006 RT engine cutting out at random usually when it is wet at the end of a long run and occasionally when it is dry. engine justs dies when the clutch is pulled in and it restarts on engine push starter button or if the ignition is switched off then on again. i have noticed that it is at the end of a run with quarter tank or less and seems to be ok when tank is refuelled .
Any suggestions on what might be causing this . dealer as found no problem and said just reset ignition to reboot ecu. Not the best diagnostics in the world.
Reqards
Dean
Reqards
Dean
