1 - 9 of 9 Posts
First time to get my fingernails really dirty! Changed the oil, FD fluid, transmission fluid & radiator fluid. Put in a HID low beam and added PIAA 1100x. Put some Hyper lites on the back! Here is the problem, when I start the engine it revs up around 4000 rpms. I can get it to go to 3000 but have to work hard on the throttle. Any thoughts of what I did wrong? :confused:
Check throttle cables.
Did you disconnect the battery when you were doing the lighting? If so you need to re-teach the throttle position.
Cable was pulled tight, wiggled it and now she purred at 1000 rpms! Thanks for the help! Now to put on all the tupperware and start riding!!
disco battery
wait about 5 minutes
reconnect battery
turn igniton to "ON" and "kill switch" to RUN.
Immediately turn the throttle from idle to full throttle at least 3 times in 10 seconds or less.
Turn ignition OFF
Turn ignition ON and start bike.
You know every one makes a big deal on the TPS reset but I have found it not to be necessary. I forgot to do it when I buttoned it back up after the clutch job (battery off for two weeks) and I had nary a stumble at all. The only driveability problem I had was the one fuel injector connector I failed to fully latch in place.
Old Slow Guy in A Fast Car
John that's only because you are SO GOOD that the bike if afraid not to run good after you have worked on it. ;)
Mine eventually settles in, but the idle tends to run high for a while - around 1400 RPM.
1 - 9 of 9 Posts
